Transmission Fluid Temps
Royal-T-Ltd
Can you put too big of a tranny cooler on? Was checking out a 40,000 BTU! cooler to replace my 20000. Also saw a 29000 that looked pretty decent - so question is - Is there a point where the fluid can be too cool for proper transmission performance. I will probably still be running cooler in series with radiator. TIA
with a high stall converter, i dont think so. do you have a tranny temp gauge? get the biggest cooler you can, heat is the enemy! :cool:
