Trans fluid does need heat to prevent Oxidation & Condensation making a home in the Trans which is as bad as in an Engine. The Glue/Bonding agent used on Clutch Frictions is water based. Driving in cold weather with an External/Auxillary Trans Cooler only can allow Condensation to never be boiled/cooked off.
Ideal Temp is 175*-225*F. >>
Transmission Life Expectancy - TCI® Auto
Stock Trans, Dexron III, Type-F, DexMerc. Much cheaper than Synthetics but doesn't protect as well.
Good Info & Links in Post #3>>
http://www.turbobuick.com/forums/transmission-talk/340252-tranny-fluid.html
(Dexron VI vs Dexron III)
The following chart represents the improvements over Dexron III.
Extended Fill Range = 100,000 miles Normal Use.
Change Interval = 50,000 miles Severe Use.
Clutch Friction Stability = Improved 100%
Clutch Durability = Improved 120%
Oil Film = Increased 20%
Fluid Oxidation = Improved 100%
Shear Stability = Improved 200%
Foam / Aeration= Improved 150%
