Transmission Pan Upgrades
JerseyGN
Alright, I'm getting read to change the tranny fluid and replace the TCC solenoid so I figure now would be a great time to upgrade the transmission pan. What are the thoughts and opinions on the Art Carr Pan (Kirban Sells) vs. the Modified Art Carr pan w/700-R4 filter upgrade (DRW Transmissions).
Thanks in advance!
Bruce,
Can you explain the bottom feeder tube/filter to me. Or do you have any pics? Are replacement filters readily available? Is it a simple swap similar to replacing the filter or is it more involved?
Is this set-up effective under heavy side loads....i.e. hard cornering. I do plan on auto-xing the vehicle some too.
Thanks again!
