Trouble starting fresh engine rebuild
turbodave231
Moderator
I beat my head against the wall trying to start this engine. It is a stock build with a mild cam. I finished it up many months ago.
Had spark
Had fuel pressure
Had injector pulse
Rechecked cam sensor timing. Good
Ran a compression check and found compression very low on all cylinders. WTF?????
THEN I remembered that it SAT with just the upper plenum bolted on the manifold. I didn't want any debris in my new build.
I grabbed my camera scope and looked down the throttle body.......And guess what I found.
Sent from my XT1254 using Tapatalk
That's what happens when you can't remember anything !
I installed a plenum gasket and problem solved!
Need to add a branch to the GM flow tree that verifies air
I was watching grams/min on my Tech1 and it didn't change when cranking.....I found out why.....I laughed my ars off!
Though you all might enjoy the story.
This is funny. I've done dumb stuff like this before.
No trees were harmed in the sending of this message, however, a significant number of electrons were terribly inconvenienced.
Funny glad to see it was something small that was just overlooked and nothing major good stuff looks like something I'd do
Sent from my SAMSUNG-SM-G900A using Tapatalk
