Jan 20, 2014 #1 J Justa_v6 Member Joined Apr 15, 2011 Messages 156 I recently found the parasitic drain in my car, the trunk light was staying on removed the bulb in order to save the battery. Does anyone know where the trunk light switch is located ? Posted from the TurboBuick.Com mobile app
Jan 20, 2014 #2 H Heisenberg Guest Actually - I thought of this a while back and It's a mercury level switch if I am not mistaken as part of the socket assembly. (I think) Attachments ExtractPage3 - of 08_06 - TRUNK LIGHT DETAIL.pdf ExtractPage3 - of 08_06 - TRUNK LIGHT DETAIL.pdf 193.3 KB · Views: 156
Jan 20, 2014 #3 J Justa_v6 Member Joined Apr 15, 2011 Messages 156 I checked my car and cannot find the mercury switch, does anyone know where it is located ? My light assembly looks like this Posted from the TurboBuick.Com mobile app
Jan 20, 2014 #4 D dartguy340 T-Type guy Joined Oct 2, 2010 Messages 565 It is built inside the socket you are holding in your hand.... Put the bulb back in, ground the bracket with a wire attached to it, and tilt the socket around and see if it goes on and off.
Jan 20, 2014 #5 J Justa_v6 Member Joined Apr 15, 2011 Messages 156 I'll do that, thanks! Posted from the TurboBuick.Com mobile app
May 17, 2014 #7 Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Messages 16,806 GNRick said: Any results? Click to expand... Maybe, he got electrocuted???
May 17, 2014 #8 G GNRick Retired member Joined Mar 21, 2004 Messages 5,485 I would bet Uncle Fester could get it to light! He could have tried putting it in his mouth!
May 25, 2014 #9 H HOFSGNX Member Joined May 23, 2005 Messages 87 Got the same problem in that my light does not work - it's grounded with a fresh bulb and will not turn on, possible solutions???
May 25, 2014 #10 G GNRick Retired member Joined Mar 21, 2004 Messages 5,485 Well I would make sure it is getting power with a test light to start.
May 27, 2014 #11 N nwarky Active Member Joined Jul 7, 2003 Messages 603 There is a metal capsule inside at the base of the socket which is the mercury switch. Very rare for that switch to fail unless damaged.
