battery relocation story, my 84 nitrous chebby car had as turnk mounted battery, the car was the typical 100 dollar car bought from my boss, that had a good bit of rear rust, well i ran the battery cable between the chassis and body for a short 6 inch portion, all was good till i was on my way to the track, after a stop light i got on it real hard to ensure she was running good and all of a sudden all quit, i thought that i had blown another distributer rotor, not so, total electical failure, ends up that the battery cable got cut threw when i got on it and shorted the cable out, melting the terminals off the battery, ends up taht when my girlfriend said that sparks were comming from the rear end the week prior and i blew her off saying that it was " impossible", well she was right, that was the start of it, you cannot believe the heat that is involved when a 850 CCA batter shorts out on a 1 gauge wire, that is why the switch is needed and why it has to be on the positive side , if that positive cable gets cut then it shorts out, turning your car into a rolling welder, if the negitive cable gets cut, well nothing, it just makes anoter gound connection. end of story note, the car broke down infront of the welding shop that my father had an account at, so i got some cable and i ran jumper cables from the trunk battery down the side of the car wrapped around the passenger mirrior and to the alternator connection, the cables couldn't carry enough current to start the car, but they would allow it ro charge the battery and run, so my friends held the cable to the battery and the starter connection, i started it up and drove home with the jumber cable flapping in the wind, another day of trying to get to the track, and oh man wasmy then girlfriend pissed, she had left ahead of us with the tires and stuff, she sat there for an hour, and she thought i had blown her off, took an hour to explain the whole story to her.
grant
