1980 Buick
- Aug 17, 2009
OK: I'm committing Sin, "but I haven't a choice".
I have an 1984 "G" Body "Hurst Olds" with a 307 "9" Engine,
Cutting to the chase, I'm trying to find out IF the PROM in the car NOW (& it Scan's "813") , is the CORRECT one.
That's it !
The Broadcast code is: 0810, "DFC". *I can't find it anywhere in the published "tables", and wondered if someone alot sharper then me ("not a tall order") COULD.
The reason why is that I have no TCC "apply" (when the proper "criteria" is met). After that, I have a "yes" to a knock signal while running / driving, ... and a "no", with just the KEY-ON. *The car has NO Knock Sensor !
Along with this, I have an "A/C Clutch "on" (when it's off on the panel) ... and a "no" for A/C on . what's interesting there is a "no" when I TURN IT ON as well.
The A/C works fine BTW ...
All this information's off a GM "TECH-ONE" Scanner.
There are other "gremlin's", (or "strange parameters) ... but those are what bother me.
Originally, I found that someone added a 2 terminal switch too the TCC (inside the Trans.) Eliminating (or "bypassing" this), along with a new Torque Converter corrected that. *The funny part is, (with ALL that I preface above) is the fact that the T.C.C worked after I did the above, on it's OWN for TEN MILES ! *I "felt" the T.C.C. go "in & out" with each touch of the brake Pedal.
THEN, I came to a stop, "turned around" ... (too go back home that same ten miles)... and then NOTHING !
NO T.C.C. after (or during that 10 mile gaunt all the way back home).
Grounding "A to F" on the ALDL gets me T.C.C. ALWAYS.
W H Y ?? ... "that's where I am".
Any help would be much appr. !
Thanks for reading !
That's it !
