Hey Guys,
Just thought I would share. I installed the motor I built for my dad's TTA today and everything went pretty smooth. The motor is a built 109 with a girdle, billet roller cam, ported heads, JE pistons etc.
The motor fit fine with the new poly mounts the only thing I noticed afterworkds is the oil pan just barely comes into contact with a small part of the crossmember on the drivers side. I am not sure if this will be a problem, guess we will have to see.
Hope that helps to all that was planning to try this!
