TTA Motor mount UPDATE:
As of 10-13-02, here is where we are at...
I have been working feverishly for the last couple weeks trying to get these ready for all of you asap. We are working with several prototypes right now, making sure we get the best possible setup. We are working with a car that has an aftermarket torque arm installed, with a heim joint on the forward end of it. This sends a lot of vibration into the car by itself, and with our mounts installed, it gets a bit much at certain rpm's. If you guys (and gals) had to wager a guess, what percentage of cars have these "solid" type torque arms? If it's 5% of the cars, it is obviously not as big of an issue as if 50% of the cars have them. I will setup a poll if you would like to vote your setup (greatly appreciated).
We have the drivers side pretty much figured out & finalized, assuming the vibration is at a tolerable limit, which it seems to be. I will be testing on another car to get more feedback this week. I may do a short run of the drivers side only right now to get people back on the road. Installation was not quite as bad as I thought, and gets easier by the 5th or 6th time
They fit up beautifully, and really tighten things up nicely. We will have detailed instructions and tips with pictures to make it much easier for you to do. I am shooting for having these available the week of the OCT 21st.
As for the pass side, this gets a bit more involved. It is a bit different than the drivers side. At first, it looked like we could just make one mount that would fit both sides. No such luck. I could just make most of it the same and change the side plates (easiest way), but that might not be the best way. I am looking at making the pass side differently so that I can get more poly in there to lessen the vibrations felt in the car. This might include a different frame pad and different side plates. I am also getting custom bushings made right now that are softer than the original TR mounts. They will still handle all the power you want to put to them, just lessen any possible vibrations. I have to also make a special wrench to include with the mounts to be able to remove & install the frame pads. We got the drivers side with an extension & U-joint, once we figured out where to go at it. The pass side is mounted in a slightly different spot, and couldn't be done the same way. Best way to do it seems to be to make the wrench, just one more thing to do...
As for the prices for these, I have to do a little re-figuring now that it looks like the pass side will be different. I was hoping to keep parts the same so I could make a bigger qty of parts & keep the costs down. Now it is going to be several different parts, lower qty's, more design time, extra fixtures, extra tool, etc... Boy, just when I think I am getting a grip on things
I did come across new aftermarket motor mounts for an import car that was less involved than the TTA mounts, and they were $459 for 3 pcs! The TTA's will actually be 4 pcs, with a special tool included, and a much lower qty being made. Our price for the whole kit (both sides, mounts & pads & wrench) will be less than that for sure. I should have a firm price on at least the drivers side by the end of the week so I can start taking orders. It will probably turn out to be like I made $0.50/hr if I am lucky after all the time I have in this project, but oh well. Got to keep the sport alive and the cars on the road!
