SignUp Now!dvernst said:Well I don't know the source personally, but he is a member of this board. The rear end came out with under 9k miles on it, and has been sitting in storage filled with fluid. He said he guarantees that you can't get any closer then this one to new. I've been looking for rear end out of GTA'S, and I have not found one with under 80k on it. I have been looking for a couple months with no luck. I'm not arguing just wondering if it sounds any better now? Thanks
I'm not sure. I know he replaced it with a Currie 9" in 1997 or 98. He also did a bunch of other stuff to it also. I'll have to investigate it better. Thanks for the help so far.Razor said:80k is a non-issue.
Why was the rear end pulled at 9k? If the car was burned, wrecked in the front, turned into a ProStreet, etc.. then you have my blessing
If it was raced and eventually replaced before it broke.. then you have an issue. 9K miles can be very hard miles on a TTA.
My TTA has only 18 K miles![]()
Thanks. Yeah if it actually weighed 300#'s you definitely wouldn't have been able to move it around. 297#'s is nothing though.UNGN said:I bought one last year and it was 300#. At least that is what the trucking company said it weighed.
Moving it around, it seemed more like 297#'s.
Razor said:Get it from something weak.. like a GTA.. and the 88 GTA's have bad calipers..
wickedsixx said:Dan,
Do you know if the TTA rear has the same torque arm mount on the housing as everyother thirdgen?....if it is then there is no sense spending big money on a rearend just because it came out of a TTA when you could get the exact same rearend out of a GTA or an IROC for half the cash....or less.![]()
O.k. the rear end was pulled, because he was planning on putting a Trans brake, and did not want to break the stock rear end. I know it's a TTA rear, but I like the fact it only has 9k on it. I have not found one comparable to it yet. I've been looking on every forum I can find with no luck. Maybe i'll get lucky and come across a deal on a 9". :biggrin: ThanksRazor said:80k is a non-issue.
