Vaccum canisters do not work well, your booster is a canister of sorts. When you empty that canister it takes to long to build up enough vaccum for repeated use. I was looking into a pump to help out wired to the brake switch to turn on when I hit the brakes. Other issues came about which makes it an easy choice to go into the motor(originally didn't want to do that).
