Details of the run:
60'......1.62
330'....4.75
1/8.....7.42
MPH...90.69
1000'..9.70
1/4....11.61
MPH..115.77
Your Screen Name Here...TTA1387
EMPTY WEIGHT: 3550
BLOCK:stock
HEADS: stock
TRANSMISSION: Built by Andy Lahoskay
TORQUE CONVERTER: 3200 Vigilante
DIFFERENTIAL: stock
INTERCOOLER: stock with screen still attached
THROTTLE BODY: stock
RJC POWER PLATE: yes
INJECTORS: 50#
THERMOSTAT: 160
TURBOCHARGER: PT51
VALVE SPRINGS: John Pearcy
MAF: stock with one screen removed
DOWN PIPE: Terry Houston
EXHAUST: SLP cat back
FUEL PUMP: Walbro 340
FUEL PRESSURE REGULATOR: ATR stock adjustable
FUEL PRESSURE: 43
ALCHOHOL INJECTION: SMC 1 nozzle
PROPAIN INJECTION:
NITROUS:
AIR FILTER AND AIR INTAKE: 8" K&N with ATR maf pipe
TIRE DESIGN, SIZE & AIR PRESSURE:Nitto Drag Radial, 245/50/16 at 20psi
AIR BAG(s):no
SCAN TOOL:.Direct Scan
FUEL:93 octane
CHIP:TurboTweak
CHIP TIMING:18 degrees in 3rd gear
KNOCK RETARD:0.0
OXYGEN SENSOR VOLTAGE:780-800
TRACK ELEVATION:+50
TEMPERATURE:70
PEAK BOOST:23#
BOOST AT LAUNCH:?, launch at 3000 rpm or when car starts pushing
MILES ON THE CAR/ENGINE:35K
60'......1.62
330'....4.75
1/8.....7.42
MPH...90.69
1000'..9.70
1/4....11.61
MPH..115.77
EMPTY WEIGHT: 3550
BLOCK:stock
HEADS: stock
DIFFERENTIAL: stock
INJECTORS: 50#
THERMOSTAT: 160
TURBOCHARGER: PT51
FUEL PRESSURE: 43
PROPAIN INJECTION:
NITROUS:
AIR BAG(s):no
FUEL:93 octane
CHIP:TurboTweak
KNOCK RETARD:0.0
TRACK ELEVATION:+50
TEMPERATURE:70
PEAK BOOST:23#
