Your e-mail and current build would help us alot in sending you a file that would be benificial to you.
burner_0352@yahoo.com
As for build info...it's not my car so I'll tell you everything I can remember about it.
Engine
-Standard block with all the tricks that are supposed to make it live at 600+hp. pistons, ARP, cometic, oiling modifications etc.
-8.5-1 Compression
-Bored .20-.30 over (Not sure exactly how much)
-Non stock iron heads (I wish I had more info to give on that)
-Cheap stainless tubular headers, big downpipe, electric cutout, flowmasters
-Large stock appearing turbo built by precision turbo (I wish I had more info to give on that)
-air to water IC
-Hemco doghouse
-Boost set at 12psi for break in (Wastegate pressure)
Fuel
-Wablro + Bosch booster
-95 lb/hr injectors
Engine Managment
-Classic FAST standalone running bank to bank and speed density
-3 bar map
Is this a Classic or XFI? Where did you purchase it from? Whoever it was should have supplied a start up program. If it was a used Classic, it should have had some sort of Buick program in it already.
Not sure where the fast was purchased as it has been in the car for several years but as far as I've seen has never had a decent tune on it. Currently I've got the car is decently tuned (with no knock and safe AFR's) up to 12 psi but I would like to compare my guesses for VE and timing advance at pressures higher than 12 psi to someones working map.
