I got a buddy with a 89 TTA that has been worked on by a friend of mine, but i'm not sure how he's tuned it. Its a stock motor, running 18psi of boost, stock injectors, with a SMS(?) alchohol injectioin system. It also has a MAF LT1 + translator. My friend has this car running so rich that when he stabs the gas and i'm standing behind the car, it makes a HUGE cloud of black smoke and I almost choked. I know a little about these cars, and presently i'm working on getting his direct scan working. I took the MAF translator and turned the base from 35% rich to 0%... and left the WOT at 2%. The alcohol is supposed to come in at 12psi of boost. The guage on the alochol shows that it injects at 63 psi. I'm not sure what the base fuel pressure is, but i was thinking about turning it down a little bit and turning the WOT up 5%. Also, i'm thinking about adjusting the TPS sensor because the only time you can see black smoke is when he jabs the throttle.
