What are you trying to accomplish? These cars are easy to tune. Add octane and turn up the boost. How hard is that?
The only caveat is that the car just has to be in good, working condition.
So many people have bad fuel pumps, plugged up exhaust, leaky headers, broken sensors, mismatched combos and then bitch that they can't run 11's on 93 octane and radial TA's.
A newbie playing with fuel pressure will get them a one way ticket to a motor rebuild. No matter what anyone tells you, fuel pressure is NOT an acceptable substitute for Octane.
Get a scan tool. Make sure eveything is in order, use a chip from a reputable vendor and set the fuel pressure to what he recommends and LEAVE it there. Turn up the boost slowly until you get a slight amount of retard on the 2-3 shift and Walla, you've achieved the optimum state of tune for the amount of octane you are running. If you want to go faster than this, you only need to add better gas and repeat.
What could be easier?
