Thanks. Is there any way you can give me the actual diameter of the stock 86-87 turbine wheel (major and minor)? I can't find it anywhere and I'd like to know just how much bigger it is than the "standard" T3 wheel in the 84-85 turbos that I have. Give me an idea of exactly how much more air it can flow. In that thread you only show/discuss the early 3.8 & TTA .82 wheels and the 86-87. No mention of the 84-85.
Given that I don't have 2 matching .82 housings I may just start mocking things up with the 84-85 turbos with the T4 compressor housings bolted on. In the mean time I can start hunting for either 2 complete 86-87 turbos or at least the turbines & housings. I can always try the setup with the standard T3 turbine and if it chokes off the engine upgrading to 86-87 turbines & housings (or even aftermarket ones) will be an easy bolt on with no fabbing. Where as the .82 housings, with their different exhaust elbow bolt pattern, would require changing the elbow and/or piping.
Although I am curious just how bad the lag would be with the .82 housings. I have a 2700 stall converter in the car and currently the engine doesn't come on cam until about 3000 rpm. (It really needs about a 3200 stall converter). So I am dealling with a bit of "lag" already.
