SignUp Now!Thanks Lonnie for the explanation. So I take it the rearend let go and the engine went to redline, overspeeding the direct drum. What in the sprag assembly let go? It let go without the intermediate clutch being applied?
I was wondering what sort of advantage there could be by going to an inferior synchronized style shift with a 400.
Why not use the double wound spiral rings from a 4L80E? I'm sure there's more to it, because I know Lonnie and others know this trick.
I never tack weld on a TH400 retaining ring anymore.
They spread too and pop off. Ask me how I know. It's got to be a gorrilla of a snap ring (like a super high tension c-clip) or Tack with a liitle si-bronze.
That must be what was used to tack the last drum I got. The tack was an off color. Not a normal steel material tack. I'm sure a much lower melting temp.
Yes. I've heard of spirolocks popping off too.
What about a retainer to retain the snap ring, similar to how they do it with the AOD?
Don,
The spragless setup is a complete drum assembly made with the intermediate clutch race as part of the drum.
Mike,
I've had TH400's at 12,500 rpm in monster trucks with the 4L80E ring...
I've seen the TH350 snap rings come off in Bonneville Salt Flats trans at ~8000 or so. So I use the spirolocks on them now too, but the ones I use don't have the "tangs" like the GM 4L80E piece does.
there is a rigid od retaining ring with two eyes that fits right in here and never comes out.it isnt easy to get in,you need a real heavy duty snap ring pliers like the ones used to remove the pinion bearing retaining ring on the old 413 chrysler,but that is an external ring.i also put a rubber band around the tips so the pliers becomes spring loaded.Don the outer race is bolted to the drum.
Wow guys.I leave for a day and come back 20 post later .Thats why i like this board so much cause it has a wealth of knowledge and a bunch of good guys.........I called you were gone.
Whats up john. What do you have for a 400.Take care we need to talk. Called a couples times.I need to call you, wish you were closer I have a 400.
