Originally posted by brewmeister7
.The general concensus around here is that water cooling will not help a whole hell of a lot.My last section had water cooling but was not used.Who knows,might have lasted longer if it was.
I disagree but that's just my openion. If you notice most all newer turbo'd cars have provisions for water cooling. Why would they bother if it wasn't worth while? Especially in the auto industry where they cut every nut & bolt possible to save a dime.
If you were mainly going to use the car for drag racing you could pump
ICE cold water through the turbo instead of hot radiator water. IMO that would HAVE to bring down your compressor temp. & the colder you can make boost pressure, the more torque your engine will produce.
All you would need is an electric pump & an ice chest.
It would be simple to do.
So, here is my question
Can we get water cooled center sections for our cars
Will they bolt up like a normal section that doesn't have it
If so I'd like to go that route when I rebuild my turbo
Glad to hear you got done right from the lady selling those kits.
I've contacted her before.
I'll prob. be picking one up before to long, I have some spare turbo's to fiddle with now. Also glad to hear it was so easy for you to change it out. It looks like I'll be needing a big breaker bar to get mine apart
If only I had air tools
