nocutt - thanks for dropping in! the emphasis in my statement was on 'don't know', not 'not worthwhile'. as of last week, you hadn't posted any driveability or power figures in your thread. it's encouraging that you get useable boost at 1900 rpm...
LOL...the thread is never real time...never :wink:
Well I have this engine in a much lighter car and even the tire footprint does not really help. The tires go up in smoke so I had to artificially change boost threshold; between 2300-2600RPM dependent on the color of the sky lol. In any event, it is a testament to how the xhaust manifold was designed and other ancillary devices etc
cstavro;snip 2 said:
...cartuning states "This upgrade turbo is a 61mm PT-61 capable in excess of 700 crank hp with lagless operation... A turbocharger with boost by the time you are at 15% throttle." full boost by 2600. i believe it to be a p trim .63-.68 a/r t4. this turbo spools nearly as quickly as yours, and you use a boost controller to delay response - you might consider a larger compressor
i believe a 61mm p trim std bearing turbo will spool quickly, good for low 11s (with cam and heads), and i'll forego the 67...
Well I cannot say first hand what the cartuning specs do, but I used a modified gn turbo years ago in a series2 and this was way smaller than what I have now, we are talking .60/.63 with a 4X mm comp wheel and boost came in at about 22XX-23XXRPM, fullboost was about 28XX-29XXRPM and plateau'd around 55XXRPM. A regular constant type turbo manifold was designed. In other words Cartuning is using a marketing ploy" over-rating"
...it simply does not make sense physically for them to be able to get fullboost by 26XXRPM. I will not go into their design specs is serves no purpose.
edit: I quickly went on clubgp to do a search here; good supporting info
ClubGP Message Forum troubleshooting
cstavro;snip 3 said:
...being a stickler, i'd want equal length header tubes. a 12" length difference seems significant. i.e. cyl 1-5-3 fire at 0°, 240°, and 480°, respectively. the pressure pulses (independent of actual fluid speed) will reach the turbo at 35°, 270°, and 505° at 6000 rpm. they're still not arriving at equal spacings (the purpose of using a divided housing). i don't how this translates to spool or hp.
i've read that headers aren't worth the cost over stock manifolds even in a 10 second car
logs benefit fab time, ease, and spool - and apparently don't lose much to full headers. i would, however, build the log with a 6°-8° cone instead of steps. 321 stainless, or even coated carbon steel is better than 304...
As you have seen it is very difficult to design "true" equal length headers with this claustrophobic engine space afforded by GM ...I am sure it is feasible but one needs lots of room to accomplish this. It is either you do a Pulse design or constant pressure system...they both have their merits, but as a street car my own emphasis lay in quick response, stock converter and a much broad power curve, in which case the pulse design was a better idea. The torque curve seems to be much broader like a "little turbine". Again different "means to an end". As far as hp and type of system goes, it is really difficult to say which setup favors power more granted we are working with what GM gave us. Again in my mind, the area under the curve should dictate that and since in this system the turbine is actually working much harder I would say there may be a much broader curve than a constant pressure system...that is an educated opinion, I will see when I get on a dyno...but definitely spool 101% faster.
cstavro;snip 4 said:
...i also don't like the throttle body right above the exhaust/turbo. can you rotate the l26 intake 180°? this will also shorten the intake piping a couple of feet...
Never tried it (don't think it would fit...strongly), but for me it was a necessary evil...I am not a daily driver and that was a compromise. That area is wrapped, shielded and hood louvered, plus the tb is smaller less surface area to heat...
If you want the intake pointed the other way, you will likely have to design yours or get an FbodV6 (lot of work though)
cstavro;snip 5 said:
...i've heard stock gs stall anywhere between 1800 and 2600 rpm. i've seen 2000-2200, but then i wasn't pushing it as far as i could. i hate the difficulty in getting good numbers. i've even gone to gm and i was told it's 'confidential'.
your car burbles...do you have the turbo cam in? i also hear the buick turbo snort
The supercharged version is around 1800RPMs, while the N/A variant is about 2200RPMs stall respectively. Now with a turbo behind I really don't know what it translates to...even higher stalls? never noticed it :frown:
I personally wanted to avoid higher stalls anyways.
Couple of folks swear that I have a "turbo cam" in there, but it is a stock cam...must be the tune :tongue:
