BlackBeauty
- Dec 15, 2001
Hey folks, I have a problem with this hose. It is a little bit too short, so that every time I boost, this hose gets blown out of place and I hear a loud howling from the turbo. Then I will tighten the worm clamps down harder, and try again, but still, under low boost, the clamps get blown off. I need to find a replacement that's about 3" long, with a 2" ID, but I have checked local parts stores, they don't have any universal rubber or silicon hoses. I was wondering if I could buy some radiator hose, just any application as long as it has a 3" long straight piece, to use for the turbo to i/c connection. Will the radiator hose be able to handle the high heat of the turbo? Are there any other suggestions? Thanks.
