I bought my GN a few months ago and I am trying to sift through what the car is actually equipped with. The turbo is in question and I would like for you guys to take a look as I do not believe that it is stock. The car was advertised as "stock" when I bought it and I am slowly finding speed goodies already installed
. Stamped on the compressor housing is "A/R .60 M24 Garret". The compressor inlet measures approximately 73mm i.d. The small end of the housing measures approximately 50mm. I say approximate as the measurement was taken with the intercooler hose on. With the hose on, it measured 56mm. I subtracted 6mm to to compensate for the hose and casting thickness. On the exhaust side "Garret" is stamped into the housing. The turbo is equipped with and adjustable wastegate actuator. It does not appear to be the stock turbo as compared to the info on gnttype.com. http://www.gnttype.org/techarea/pictureguides/turboguide/8687stock.html.
What do you think?
What do you think?
