RegalT-type85
- Jan 23, 2010
I think i broke it Where it screws into turbo,Not striped it. I was moving the line around heard a clunk, it screws in but i turn on the car, oil comes out. DID i mes up the line? oils coming out not from the threads, but the line area. I took it off noticed it was bend a bit(by me i'm sure) If so is there a way i can replace this?? I'm thinking of dropping the HARDLINE useing flexSS line. Something LIKE this T3 T3/T4 T60 T70 Turbo 4AN Oil Feed Adapter Line Kit : eBay Motors (item 350313010024 end time Feb-10-10 18:32:30 PST), I already have a good drain line, I use this T3,T3/T4 Aluminum Turbo Oil Drain adapter + Gasket : eBay Motors (item 350313793477 end time Feb-12-10 18:33:28 PST) with HI TEMP hose, it holds up very think,strong. IF not can anyone tell me the size fittings on the Oil line/block so i can go from there.
