The campaign will likely turn it into a turd with the re-flash. Timing will be pulled backNope. How can you prove it? Hopefully, the campaign will take care of it. Phil.
SignUp Now!The campaign will likely turn it into a turd with the re-flash. Timing will be pulled backNope. How can you prove it? Hopefully, the campaign will take care of it. Phil.
They're a turd to begin with. Keeps me busy, I guess...The campaign will likely turn it into a turd with the re-flash. Timing will be pulled back
http://www.zeltex.com/products/fuel/zx-101xl/Nope. How can you prove it? Hopefully, the campaign will take care of it. Phil.
Exactly. Calibration engineer screwed the pooch on the low octane timing tables and slew.You'd think the latest generation of PCM's would be able to account for the difference in octane without user intervention.
Premium fuel recommended and premium fuel required are vastly different. I'm amazed that someone would buy a car where premium fuel was recommended and use anything but. Some dick beater trying to save $300 a year when they are likely paying thousands in interest and losing value as depreciation faster than anything. Usually the timing is trimmed so far back the performance drops off noticeably on the premium recommended cars. The Pistons and rings of today don't tolerate much detonation. The 86-87 LC2 is premium recommended but will run on 87 octane stock. 13-14psi and probably at a constant 3-4 degrees of knock retard. People.....
20kHow many miles on these motors? Maybe the rings haven't seated yet and the motor's eating oil causing detonation?
What is the piston to wall?Definitely stock. These pistons look like hypers. Some of the thinnest lands I've ever seen, real low tension rings too. Phil.
Not sure, Brian. I can check on the next one that comes in. Pistons are coated on the skirts, wear looks good. Bulletin says as long as cross hatch can be seen thru the wear, block is ok to use. This one actually had the plugs and recalibration done about two thousand miles ago. Phil.What is the piston to wall?
