Two simple questions: first does the oil pump cover, aka oil filter adapter, use 1 bolt that is longer than the other 5? I bought a low mileage 85 TType that was using more oil than gas lol. Leaking out of the are where the oil pump cover and timing cover mate. Today started to work on the issue, figured a bad gasket and I come to find a crack in the tc cover where this extra long bolt, with a non oem pair of washers, was seated. Pictures will follow. Prior owner had just had the tc replaced at 80k and was leaking since. Did not go to an experienced tr mechanic.
Second I am putting in a new turbo along with associated mods and getting this thing out is a biatch! The upper downpipe bolt was spinning and coming out slowly when all of a sudden SNAP! Oh well sh!t happens. At least I know the remaining piece should back out easily. Anyways any recommendations for getting the lower dp bolt out ? And any other roadblocks I shoild look out for? Ive owned ic tr's since my father bought 1 new in 87 but this is my first hot air.
Thanks for any and all help.
