Turbo Tweak Wideband v6.1 chip ?
ikle
To run this chip, using 93 oct fuel, is the min. Injector still 50 lbs or is that just for if you are running E85. Thanks,Kyle.
Pretty sure its 50# injectors minimum. The whole reason I just upgraded from 42s is to be able to run the 6.1.
If you're gonna upgrade, might as well get 60's. I ran them on my almost stock 13.0 sec GN and got 20+mpg.
