Sep 21, 2008 #1 T turbo tom New Member Joined May 15, 2008 Messages 140 Whats the biggest turbo that you can put on a mostly stock GN that has good street manners?
Sep 21, 2008 #2 T turbo tom New Member Joined May 15, 2008 Messages 140 upgrade turbo I forgot to say that I have a P.I. converter multi disc lock up
Sep 21, 2008 #3 SGRIM Owner/Admin TB.com Staff member Joined Mar 1, 2005 Messages 25,757 What stall and what other if any upgrades?
Sep 21, 2008 #4 T turbo tom New Member Joined May 15, 2008 Messages 140 I believe the stall is 3200 and the injectors are green stripe 10% higher that stock.
Sep 21, 2008 #5 T t-typex1 Darkside Member Joined Dec 21, 2005 Messages 867 With the right convertor, PT6776. Thats what I have on mine. Stock long block with bolt ons. I have a Pats 10" 3400 stall, and great street manners
Sep 21, 2008 #6 SGRIM Owner/Admin TB.com Staff member Joined Mar 1, 2005 Messages 25,757 I wouldn't try over a 49 with those injectors... With your stall you could use more turbo, but that would require an injector change... You also need to make sure you have a hot wired F/P and adj regulator to start off with too...
Sep 21, 2008 #7 T turbo tom New Member Joined May 15, 2008 Messages 140 THANKS FOR THE INFO, ILL PROBABLY GO TO THE 60LBS INJECTERS AND A BIGGER TURBO SOMETIME AFTER cHRISTMAS.
Sep 21, 2008 #8 T turbo tom New Member Joined May 15, 2008 Messages 140 What Size Down Pipe Do You Use For A 6776 Turbo?
Sep 21, 2008 #9 T turbo tom New Member Joined May 15, 2008 Messages 140 What Et Is Your Car Running With Your Setup?
Sep 21, 2008 #10 T t-typex1 Darkside Member Joined Dec 21, 2005 Messages 867 I have a 3" downpipe from SE Turbo on my car. There are many different 3" downpipes for sale from different vendors When Im done and everything is fine tuned I plan to be 11.00's to high 10's
