Turbo went...Should I upgrade?
Crazygn.....what is your combo? stock Injectors?
I just want to know what Kind of boost you are getting out of it, and how is the spool up? Also when putting it in did you notice any additional turbo sound then the stock Turbo?
When i put it in it was a little loader then the stock turbo with my flowmaster ex. But i just put the atr up and down pipe on with the down pipe open and it sounds alsome you can hear the turbo a mile away.And the spool up is very fast with it kinda slow with the stock down pipe.I have a long list of stuff done so i'll give the bigger stuff.
ta-33
40lb injectors
sperco intercooler
ram air kit
87 ecm
87 rad
160 stat
Joe L 93 and 110 chips[ running 15-16 psi with 93]
atr down and up pipes
tps tec
307 pump[ hot wired]
adj reg
posi rear
could be more i forgot
In need of a real good tune and a scan tool
