Turbo what is it??
GNX 120
Got this turbo with a lot of buick parts I purchased, not sure what it is it says air research .95 on the compressor side and nothing on the exhaust side. Has a 4 bolt flange. best I can measure the compressor side is about 73 to 76 mm and the exhaust side is 93 to 96 mm. Any help with this would be great. THANX KERRY
To be perfectly honest, it's going to almost 100% impossible to properly ID it without full blown Inducer and Exducer measurements of the wheels. Pictures really help as well. If possible, pop the compressor cover and turbine housing off the turbo and measure the wheels. It would greatly help us get a better idea what you have.
You can use this picture to see where to measure the wheels.
Hope this helps.
Patrick
Turbo what is it
Thanx I will remove and measure. Here are some pic's.
OK took it apart few pic's and measured the best I could. Don't really know how to read the veriner??? if thats what you call it. Here we go compressor side base of wheel is 4 3/16" or 4.250 if that is right. tip is 3 3/16 or 3.150 exhaust is 4 5/16 or 4.310 at the base and 3 3/4 or 3.884 at the tip. THANX KERRY
Turbo?????
Hope this helps.
Patrick
The calculations are only as accurate as the given values, example:
Compressor side numbers
4 3/16" = 4.1875" = 106.36 mm
4.25" = 107.95 mm
3 3/16" = 3.1875 = 80.96 mm
3.15" = 80.01 mm
Either way this is a big turbo...!!!
In to mm (inches to millimeters) and mm to in (millimetres to inches) Online Calculator - Converter / Conversion Chart / Table
Exhaust Side
4 5/16" = 4.3125" = 109.54 mm
3 3/4" = 3.750" = 95.25 mm
3.884" = 98.65 mm
Conclusion is ...... I have no idea..... way to big for my Buick!
Chuck
4.25" = 107.95 mm
3.15" = 80.01 mm
Exhaust Side
3.884" = 98.65 mm
Chuck
Garrett TV81 used on detroit desiel motors, Large FREAME T6 flange
Not sure what it is worth?? It is clean and tight, just slight shaft play. Make me a fair offer and I will consider it. #774 696 3585 THANX KERRY
i have a friend thats has one on a sbc, he looking for another..he told me to see what your looking to get for it...
I asked a few people about price they said about $400 to $450 ?? Does that sound fair anyone ? THANX KERRY
kerry,, i dont want it,, it was another guy thats asking about it,, i will tell him
