Turbos, stock to 1000hp. 57, 59, 61, 62, 63, 64, 66, 67, 70, 72, 76
Anything for hot airs?
I do them as needed. I don't stock them on the shelf. I can easily do a t04e60 compressor and stage 3 turbine in a stock 84-85 turbo. It's $675 plus $125 core
what kinda prices do you have on head porting? different stages?horsepower etc. for a hot air.
I have a few sets of champion iron heads. The difference in price depends on the spring setup they get. $xxxx for a set for standard hyd rollers. $xxxx for a set setup for an aggressive hyd lobe or solid lobe. The heads come with a spec sheet for the springs so you know what you're getting.
Hello , looking for champ iron heads and 1.65 roller rockers. I have new springs , retainers and locks. What kind of deal can you put together. I have a stock block stroked and hyd roller.
I have a few sets of champion iron heads. The difference in price depends on the spring setup they get. $1050 for a set for standard hyd rollers. $1450 for a set setup for an aggressive hyd lobe or solid lobe. The heads come with a spec sheet for the springs so you know what you're getting.
Brian, did you see my thread here?
http://www.turbobuick.com/forums/index.php?threads/407913/
Do you have any input on this problem. I figured that since you were putting together champion Iron heads you might know something. Thanks.
Hello Bison,
I am fairly new to the Buick world and I was given your name by someone I really look up to for a turbo. I currently have a Precision/Journal bearing 70mm w/internal gate. I have upgraded my down pipe to a 4" with a V Band and I current still have the three bolt headers. I would like a Ball Bearing set-up that will make more HP at less boost then my current 70mm. The engine dyno'd well over 600 w/current set-up. Please advise....
Brian, got any 6262s? Not sure if the 6265 will be too much for my setup. I'm ready to pull the trigger on one.
Hello Bison,
If you aren't over 75lbs/min with out current engine there's not a turbo out there that will make more power at less boost without going to a larger turbine and building the engine to pull more rpm. I can offer you a 6766 that has been 8's but like I said I wouldn't expect more power with less boost.
