ENGINE PARTS
6876 Presicion Turbo with actuator (Heavy Duty) 400 miles on this turbo $800
TA49 turbo, works but has up and down play, selling as rebuilder $125 SOLD
109 Block standard bore $300
Inercooler Bracket (Drivers Side) (2) $15 each
Intercooler Bracket (Passenger Side) (2) $20 each
Crank Pulley (complete) $40 SOLD
Stock Rockers (set) (3) $15 each set
Motor mounts (on frame) $15 set
Stock Fuel Pressure Regulator (2) $5 each
86-87 Engine Oil Dipstick $20
86-87 Oil Dipstick Tube $20
Intercooler Shroud (upper half only) $10
1/8" Valve Cover Spacers (set) $20
Power Steering Pump + Pulley (2) $35
86-87 Drivers Valve Cover (nice aluminum paint) (3) $15 each
High Torque Mini Starter (farely new) $75SOLD
Vacuum Hardlines (Front) (3) $25 each
86-87 Fuel Rail $30
86-87 Injector Harness $25
Tensioner Pulley (with bolt and washer) (2) $15 each
Turbo Saver (with larger feed line to Turbo) $50 SOLD
Header Heat Sheild (drivers side) (2) $5 each
Air Cleaner mount bracket (stock) (2) $5 each
Air Cleaner Box (stock, bottom half only) $10
Oil Cooler Adapter (w/nut) (2) $15 each
Starter Heat Sheild (2) $5 each
Coil Pack Bracket (flat one) $20
Stock Wastegate Actuator $15
Adjustable Wastegate Actuator $35
Wastegate Solenoid (known good) $30
Stock Connecting Rods $35 set
84-85 Trans Dipstick $10
NEW CAT Girdle w/hardware (2) $250
Engine Shortblock (unassembled): .020 over TRW Forged Pistons on reconditioned rods, stock crank (needs pollish and balance, at most maybe 10/10), .020 over block (hone it and go, ARP main studs (already line honed)), baffled oil pan, Front Timing chain cover, oil pick up tube, flywheel, front balancer, NEW rings (need to be installed on pistons) $1000
will throw in a new CAT girdle for $200
Engine Shortblock (complete, assembled): Low miles on build (maybe 150 miles), .030 TRW Forged Pistons, crank is 10/10, rotating assy is balanced, oil pan and front cover included, throw in a cam and go $1500
BODY AND SUSPENSION
Complete set of 86-87 T wheels with almost new stock size white letter tires. NICE!! $450
NEW Lakewood Front 90/10 shocks $75SOLD
AC Heat Sheild (3) $10 each
Marker Light (passenger, black) $20
Headlight Bezel (passenger, black, NICE, newly reconditioned) $50
Taillight w//bezel (NICE, new reconditioned, black) $75
86-87 GN Center Cap $25SOLD
Wiper Arms (black) $35 set
Wiper Arms (chrome) $35 set
Windsheild Trim (chrome, outers only) $15 for both
Wheel Well Trim (black, drivers rear) $40
Air Bags (set with valves but needs new lines) $40 SOLD
Air Bag (just one bag) $15
Hood hinges (needs repainted but no slop) $10 set
Muffler Hangers (stock set) $20
Headlight rings $5 each
Headlight bucket $5 each
Trunk Latch (2) $5 each
Hood Latch w/bracket $10
T Hood Ornament (nice shape but not perfect, bought from Kirban) $50
F41 Cross Brace (side to side brace) $40SOLD
Rear Window insert (metal between rear window and trunk lid) (have one for hardtop, one for vynal top) $25 each
License Plate brackets (stock, rear) (3) $5 each
Bumper Spacers (10) $2 each
Remote Mirror (drivers side) $15
Door and Trunk Lock Set (chrome w/key) $20
BLACK TRIM, Random Pieces $ASK
RANDOM PARTS AND INTERIOR
Grey T Carpet inserts for sail panels $25 set
GN Upper Door Panel (drivers side, driver quality, wear on top) $20
DASH Pad (84 GN, Very Nice, almost perfect) $50
AC Box Top (mesh part) $20
Sill Plates (6) $15 each
Cruise Control Set up (86-87, bracket, module, and cable) $35
84-85 Cruise Control Cable $10
Shifter Assembly (2) $35 each
ESC Module (known good) $35SOLD
Gas Pedal with bracket $15
EGR Covers (stock black) $5 each
EGR Cover (chrome) $10
Heat Sheild ( Over Cat Converter on floor board) $15
86-87 Taillight Harness (Nice) $35
Body Harness (from fuse block to taillight harness) $25
VSS Sensor (vehicle speed sensor, known good) $30
