turn or hazard light flash for car alarm
Olli.D
I like the turn lights back and front flashing, while alarm occurs or on/off the alarm.
There are 2 outputs (right / left) at the aftermarket alarm system for flash lights.
I found every of 4 blinking ligts cables under the steering, but there is a special with brake off while blinking, you know.
So not possible just to connect front and back flasher together.
Is there a possibility to connect it, may be by hazard relais or switch, without using diodes or relais?
Regards from germany,
Olli
I don't think so....tire into the parking lights (brown wire) instead...that will still give you light all the way around
