Turn Signal Question
87Turbo-TWE4
This a probably a stupid question but when one turn signal bulb goes out does it affect the other bulb and vice versa? Neither of mine work and when I go into boost the turn signal light will flash on the dash.
you have some other issue- the left and right turn signals are essentially separate circuits that use the same switch and i can't see why the boost level would affect the turn signals..
what does it do when you have the hazards on?
What I really meant to say was that when I use the left turn signal, the front and rear do not work. The parking signal will work but I have not tried the hazards. I guess it's electrical.
The signals do not flash but will show on the dash like they are. The signal on the dash will also stay solid and not blink.
