turn signal stalk
Get some thin wire even fishing wire and disconnect the connector under the dash first and fish that out when you pull the stalk out. I think you twist it slightly to the left while pulling it out. It just "pops" out. Same thing when putting it back on a slight twist to the right. Pull your wire down and just pop it back in place reconnect the connector and you should be good.
In a pinch you the wire is stiff enough you can fish it down without the fish tape if you have to
does anyone have a pic of where the wire ties (connects to) under the dash? I'm in the middle of this upgrade as well. plz
