Twin Turbo setup COMPLETE NEEDS TO GO!!
turbobuick
Staff member
You got some serious fabwork on this setup...Whats the dimensions on intercooler looks custom? Does it fit in the stock radiator core?
It is a CAS V3 and it does fit a stock radiator support. It was mounted differently in this setup than typical. The bottom of the core support is cut out and V3 is mounted with the inlet and outlet up top instead of down below. This takes away ground clearance issues. Down pipes are also routed in the stock location instead of under the cross member. With the IC tubes tucked up top and the downpipes on top of the x-member you dont have to worry about ground clearance of smashing stuff when you wheelie the car. It will need a custom core radiator for which I have all the dimensions and specs.
I am planning on having the motor and all the parts at Norwalk Sept 8.
Offers? I am planning to have the entire set up at Norwalk Sept 8.
This is a smokin deal!!!!! No way you could ever duplicate these parts for three times the price.
Good luck with the sale.
Thanks Dave, unfortunately it seems racers who want to go fast with a Buick V6 are what is in short supply these days.
