TYPE F fluid yes or no?new thread
norbs
Classic fast, XFI, SPortsman & MS3 programming
I have to start a new thread since mine was relocated. Not sure if i can keep pushing the car around in the garage since it has no transfluid in it. Should i put type F in or dextron? :confused: :confused:
I switched to Type F at the beginning of summer. Seems to work just fine. Have done a lot of driving this summer as well, including Power Tour. It appears to be holding up and performing well so far. When I change the fluid again this winter I'll replace with Type F again.
I run one of Bruce's trannies.
walmart up here does not sell type f wtf? They did have tdh tractor fluid, is this the same as 424 oil?
Vince Janis recommends the good ol Dexron III w/ Mercon V fluid...seems to work fine in my rebuilt tranny?
Norb's
Wallymart does sell Type F, only in 1L bottles, no 4L jugs. Also their TDH tractor fluid has the same specs as Mobil 424.
Paul
I bought some , petro canada duratrans tractor fluid here are the specs
Typical characteristics are shown below:
Duratran
Viscosity cSt @ 40°C 60.1
cSt @ 100°C 9.5
SUS@ 100°F 307
SUS@ 210°F 57.9
Viscosity Index 141
Brookfield Viscosity, cP @ - 20°C 2670
cP @ - 35°C 23,700
cP @ - 40°C 61,200
Pour Point, °C / °F -45/-49
Flash Point, °C / °F 239/462
Total Base No. 10.6
here are the specs of 424 mobil tractor fluid
Typical Properties
Mobilfluid 424
Viscosity, ASTM D 445
cSt @ 40ºC 55
cSt @ 100ºC 9.3
Brookfield Viscosity, cP (@ -35 C) 55,000
Viscosity Index, ASTM D 2270 145
Pour Point, ºC, ASTM D 97 -42
Flash Point, ºC, ASTM D 92 198
Density @ 15ºC kg/l, ASTM D 4052 0.884
Heavy-duty transmissions, differentials, final drives, hydraulic systems, power steering systems, wet brakes, PTOs and hydrostatic drives
Recommended in off-highway industries including: agriculture, construction, and quarrying
Recommended for top-up and refill of systems
Suitable for commercial transmission applications requiring Type A (Suffix A), Dexron and Type F fluids. Do not use in passenger car automatic transmissions
May be used in applications requiring API GL-4 or SAE 80W grade lubricants in all gear applications except hypoid gear designs
Outstanding replacement for engine oils recommended for hydraulic and transmission systems
Could anyone who switched from Dexron to Type F feel a difference in shift firmness? I have an 85 GN tranny in my 87 and the shift kit shifts a little too soft unless I give it more throttle than usual. I plan on putting a billet servo in it soon.
