salvageV6
Daily Driver
- May 25, 2001
My cars both have the powermasters in them.
I am not done yet with the install, forgot to get wheel bearing grease and I hurt my back so I've been driving the GN for now, and won't get to do any more work until probably Wed.
I just started taking apart the second side and had to machine some new crush washers since the ID was a bit small, they don't sell them for the application, you need to bring your banjo bolt with you to get them the proper size.
The counter guy said they usually come with new hoses and aren't listed separtely in his books, he just stocks them in various sizes and I guessed a bit wrong.
I have only used GM semi-metallic pads and one set of carquest semi-metallic replacements on that car, and of course the front wheels are stained a lot.
I would keep an eye on semi-metallic pads and any wheels you want to keep nice, I use cheesy cheap Mangels and American Racing rims since they are about as light as stock T's, come in decent widths etc., lighter than GN wheels (for my other car), and are a good strong daily driver street wheel unlike some other light weight racing wheels, and cheap of course.
A plus is the AR-23's even look good, unlike my other A.R. set which scream 1989.
I didn't really buy those pads to keep the wheels clean, I just thought they might be an upgrade from the GM stockers. I think someone from the other board recommended the Performance Friction name and I picked the most similar to what I thought would match the GM semi-metallic replacements.
And ordered them when I bought the new calipers.
However I did notice the surface area on them is much smaller length- wise than the semi-metallic pads that came off the car.
They have bevelled leading and trailing edges on them and less surface area to stop with.
Width is the same.
I will try to take some pictures of them tomorrow to show the differences.
I am sure there is a reason for it.
Having two turbo driver cars makes you a bit slower getting things done, and a lot less desperate in having to get anywhere. :biggrin:
Width is the same.
