My car ('84) ran fine, then started to not take any throttle, then it would barely idle, now it won't even start.
I've unplugged the MAF, no difference. I checked the codes and got a "13". I replaced the oxygen sensor.
It will try to start, and sometimes lights, but only for a 1/2 second.
It had been converted over to the newer coil pack, it has three oblong squares on top. Weird, though, the firing order looks wrong but the car ran before. The #1 on the coil goes to the middle (#3) spark plug. The #3 on the coil goes to the #1 spark plug.
How do I check for a defective coil pack? How do i check for a bad module? Is the module the part underneath the coil pack?
If I can't find the problem can someone help me push it off a cliff?
Thank you,
Warren
![Eek! :eek: :eek:](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f631.png)
Thank you,
Warren
