UMI Lower Control Arms
Sal Lubrano
I just placed an order since today is the last day for the sale. My question is this. Should I have purchased the hardware (Bolts and Nuts) as well. If I reuse the OEM hardware will that pose a performace issue or will it just be looks.
Sal
Hello Sal,
Thanks for the order
You will only need the new hardware if you think yours is not reusable. Depending on the last time the control arms were removed and the weather the car has been driven in the bolts can tend to get very rusty and hard to remove and reuse.
The bolts we supply are equal in size and strengh as the stock bolts, if you think yours are reusable you will be fine.
Hope that helps!
Ryan
I needed longer bolts but I also installed the ATR rear sway bar at the same time.
Sal I installed my umi lower bars last night along with an ATR rear bar.
Be sure to have a friend help push the bolts in the rear end mount; even if you take out one lower at a time the rear will still shift some and it takes two for the job.
does anyone have that "special code" to enter on the umi website to recieve that additional 10% off ????? i have a big order so every bit helps.... ;)
