Up Pipe/ 60# injectors
bishir
Serenity Now
Looking for an Up-pipe in good condition. I'm also looking for some 60# injectors and/or chip if anyone is looking to sell.
I've got a s/s polished one that I just put on this summer. $60 plus shipping. I'm putting my car back to stock so ALL my performance stuff is for sale. Except for the FP, Hotwire and exhaust.
what kind of chip are you looking for? I have the injectors and a extender chip for them. $325 + shipping. The injectors are less than a year old and are like brand new and the Extender chip has never been out of the package.. Scot w.
What type of extender, the extreme? Fullthrottle site says the regular one is for injectors under 50lbs. LMK, sounds good.
How much for the stock style up pipe.
No it's the extender (not the extreme) and the only difference between the two is the extreme can do a couple more things and read more MAF range thats all. The reg. Extender chip can read up to 512 grm of air per second.. Here is the chip# BW054B1F
Example of chip code:
B= datastream
W= new high speed with IAC and crosscounts, requires scanmaster 2.1
O= 60lb mototron injectors
5= 98octane, 23/21 timing low/high gear (good for alky)
4= wastegate, 85/80 (good street setting)
B= Idle/rev limit, 800/6000 for cams from 200 to 208
1= Anti theft + convenience/ valet mode
F= current software revision "F"
And there is no problem with the 98 octane setting, with your fuel press set to 45lbs and 93 octane your ECM will adjust it out anyway unless you have the translator + then you can do your changes as needed.
There is the info on the extender chip.. Scot w.
Are those chips translator specific? I think I was confusing it with the commander. I don't have a translator, but if they dont' require one I'll take it. If not, lmk how much you want for the injectors only.
I'm not shure if they are translator specific or not..???
