turbo6mike
Mike Ruminski
- Sep 6, 2004
Congrats Rob. What the hell go for a 9.5!
SignUp Now!This is on pump e85 from speedway, it tested e83 i think. I dont really sweat the content as long as it is the 80s. The cam is a 210/215 roller from full throttle. The changes i made before having the shut down problem were the 85mm mas and non resistor autolite racing plugs. I just changed both just to solve the problem. I never had issues with the racing plugs, but wasnt ruling it out. The turbo is pretty well spent at this point. The cast 67 will go a little further, but the p trim turbine is the choke point at this level.Holy Sh?t, WOW Rob, your brother's car is really going. 2lbs of boost more than the 10.07 @132 pass, and 2 little changes and the car gained 5mph, that's crazy. What cam is he using, cause it seems to work very well for him and stock ported heads? I still have my TE63 turbo as a spare stored in a box, that I was keeping in case something would ever go wrong with my pt67/76 BB turbo. I think I might just throw my TE63 back in. Here I am looking to buy a new turbo and your brother is running these crazy times with a TE63, that's nuts. I never heard of these resistor plugs, they seem to work very well. I would have to find out if I could use these plugs on M&A heads. Does your brother run pump fuel E85 or the racing fuel E85?
Marco
At what rpm does the car shift or do you manually shift it. If you manually shift it, at what rpm do you or your brother shift it at and at what rpm does the car pass at the traps?This is on pump e85 from speedway, it tested e83 i think. I dont really sweat the content as long as it is the 80s. The cam is a 210/215 roller from full throttle. The changes i made before having the shut down problem were the 85mm mas and non resistor autolite racing plugs. I just changed both just to solve the problem. I never had issues with the racing plugs, but wasnt ruling it out. The turbo is pretty well spent at this point. The cast 67 will go a little further, but the p trim turbine is the choke point at this level.
What downpipe size & wastegate system are used.This is in my brothers Cutlass hybrid, it weighs 3520 with driver.
Stock 80,000 mile short block, e85, 83lbs injectors, 60psi base pressure, stock ecm with extender extreme chip, home made double pumper with Reds XP pumps, Reds volt booster, hemco upper plenum, stock throttle body, stock intake with the ends of the runners cleaned up, TE63 p trim turbo@27psi, 210/215 roller, stock rockers, comp 853 lifters, pac 1201 springs, mildly ported stock valve iron heads, stock headers, powerstroke front mount with 2.5" pipes, 85mm truck MAS with a custom 3.5" pipe, PTC 17 blade converter, 6 year old Brian Hoffer trans, stock front suspension with cheap replacement shocks, front sway bar removed, stock rear control arms, stock sway bar, air bag with 23psi in the passenger spring, moser axles, stock driveshaft with brute force u joints, old rusty shocks from the 80s or 90s (maybe even the original 1979?) New bushings in control arms, 275/60 MT pro radials. Car has stock welded motor mounts, factory fuel lines and filter.
1.39 60' off 10psi footbrake
10.007@132 27psi, 10.6afr through the run.
Thank you Sir for the info. That is a wicked ride.It is a 3.5" TH style I made with a high boost actuator.
