cutluse231
- Jun 10, 2001
Thanks to all that put in their help and their ideas
Well went and looked it over once again , my "ENGINEERED" TV bracketry to ataach the TV cable to the carb wasnt cutting it.
Found a carb throttle shaft from a Electronic 4-bbl that had all the correct locations on it for the TV to hook up to.
Once installed I measured full travel of the TV and found out I wasn't even close,I pulled the cable out by hand thought it was done till I felt resistance then pulled more (BINGO!!!).
So I marked where the tv cable would be at full throttle by the gas pedal, then relocated where my TV attached to my extension bar. Did the clicks thing at full throttle and (TAADAAA!!)
Took on a test drive and that old Regal scared me and shifted very firm and solid and kickdown ....HOLY COW!! aint the GN but HANG ON!!!
Thanks again guys
Your the best!!!!!!!
Thanks again guys
