Howdy,
Its been quite some time since I posted, after 10 years of driving, the last combo was worn out and needed a refresh. The car has been apart for 2 years, and I should have the motor ready in the next week or so. My question in htis section was to discuss my current turbo and the best course of action with it.
I know I can go mid 10's on the TE63E, but I suspect the car will easily handle much more turbo. I can put a slightly bigger wheel in the existing turbo, but I think that is rather cost prohibitive for the rather modest gains. I also beleive I could upgrade the exhaust housing to a Precision .63 housing. Again, not sure it is worth it.
The car is a street car. Just looking for input/recommendations in just casual reading it looks like the 6466 or 6766 would be about where the car should be. But I would rather ask than assume.
I'm tired of the thumbwheel and at a minimum will be doing a new chip or replacing the computer with MegaSquirt. Would love XFI but just too much at this point.
Just had injectors cleaned an flow tested they are all spot on. But again, may need to upgrade them as well.
Previous combo was:
3.8L .020 over
JE Pistons
Valley polished and crankcase glyptol'd
Polished and shootpeened stock rods with ARP fastners
Billet Main Caps
Loveridge Girdle
BGC Intake Upper and Lower
Ported GN1s
Scorpion Rockers
Accufab 70MM TB
ATR RP309G Hyd Roller Cam
ATR Double Pumper
72# Injectors
16 POS thumbwheel chip
ATR Headers
THDP
CAS V2 Intercooler
CAS Radiator
Precision Turbo TE63E with ported "fast spool" housing
Precision Vigilante multi-disc lockup converter with an o-pump (would only stall about 2500 for some reason)
Stage II 200R4
New Combo is:
3.8L .030 over
3.625 Stroker Crank
H-Beam rods
JE Pistons
Billet Main Caps
Loveridge Girdle
Ported GN1s
Scorpion Rockers
Accufab 70MM TB
Comp 218/212 Hyd Roller
ATR Double Pumper
72# Injectors (may be changing)
16 POS thumbwheel (planning to change)
ATR Headers
THDP
CAS V2 Intercooler
CAS Radiator
Precision Vigilante multi-disc lockup converter with an #6 pump ~3500 RPM stall
Stage II 200R4
Previous combo was:
3.8L .020 over
JE Pistons
Billet Main Caps
Loveridge Girdle
Ported GN1s
Scorpion Rockers
Accufab 70MM TB
ATR Double Pumper
72# Injectors
ATR Headers
THDP
CAS V2 Intercooler
CAS Radiator
Stage II 200R4
New Combo is:
3.8L .030 over
3.625 Stroker Crank
H-Beam rods
JE Pistons
Billet Main Caps
Loveridge Girdle
Ported GN1s
Scorpion Rockers
Accufab 70MM TB
ATR Double Pumper
ATR Headers
THDP
CAS V2 Intercooler
CAS Radiator
Stage II 200R4
