Upgrades to a 6600 mile GN.!!
m233roller
Banned
Here I am starting multiple upgrades to my buddies 6600 mile loaded astro roof GN.
UPGRADES WILL INCLUDE THE FOLLOWING.
TE-44 turbo
PTE stock location intercooler
Up pipe and Maf pipe.
THDP with dump pipe.
60lb. injectors and Turbotweak chip.
160 stat.
RJC Power plate.
Valve covers & gaskets.
Plugs and RJC wires.
Accufab Afpr with gauge on rail.
340 pump & hot wire kit.
New A/C Delco coil pack & module.
Tin Man cold air kit.
Alky control set up.
Complete set of gauges.
Front swaybar bushings & end links.
New tires & shocks.
Rear end girdled cover.
Moser axels.
Aluminum driveshaft.
Drive shaft loop.
Trans shift kit.
Aluminum trans pan.
Trans cooler.
Torque converter. About a 2800.
Lower rear control arms.
New Pypes race pro mufflers and tail pipes.
As of now we are leaving the virgin untouched engine UNTOUCHED !!
U forgot the roll cage!! Don't want to crack the paint....
Comp 981 valve springs and poly loc seals . miles don't matter . 26yrs of pressure.!!! Does
Dont forget some sticky tires, and address the security side of the equation..
Bryan
Wow does that look like a blast to play with! Reminds me of when they were new and everyone was playig with them like that.
Cool stuff!
KID
I guess when I said a complete set of gauges I should of said, there will be a knock, boost, oil, water, tach, A/F wideband and a scanmaster installed for now. The new TE-44 also has a new adj. wastegate on it. I'm going to set it up for right around 18 to 20 lbs. for now as I'm also installing a new aftermarket manual boost controller. Rear tires are M/T 255x60 drag radials, so I don't think traction is going to be much of a problem. I thought about new springs while I had the valve covers off but we decided to see how it runs and then maybe do springs, seals and timing chain. I'll be selling some of his 6600 mile parts off this car for him. OH, yes he's (Brian) is getting a lot of B/S about how can you do that to a virgin completely stock car? Well he's had 7 of them and one was GNX number 5 with 435 miles on it. He's been a real fanatic about keeping them virgin and stock but now says he'd like to hop one up alittle so here we GO !!
Sounds really close to what did with the 13k mile astroroof .... I went with a diff turbo I think its a pt61 with an S cover
