Upper Windshield Pillars Needed
tmpierced
Looking to replace the two upper corners of the windshield frame on a T-top Grand national. I just purchased it and went to replace T-top moulding and found lots of rot. I need to find A doner roof so I can splice in good sections. Thanx
Dave
Check with Brian at Gbodyparts.com He usually has some of this stuff. You could also check the boneyards for any T-Top G body. ie: monte carlo/grand prix/cutlass....they are all the same. .....from the factory that is....Good luck. Been there, done that! ---Keith
Thanx for the info - I'll check out the websight right away. The search begins - Thanx again!
Dave
I live just outside of Philadelphia PA. How much to chop off both sides 10 inches from each of the windshield corners (would look like two boomerangs with 10 inch legs). I can paypal you if you like.
thanx!
Dave
If you are going to replace the corners...I assume that is where it is rotted...I would highly recommend trying to get the whole top rail from A-pillar to A-pillar. Take it apart at the factory seams. It will save you from getting into allignment issues later. Trust me, I have been there. Post up some pics so we can see where yours has problems. It will also help the seller to know where to cut. Here is what I mean by taking it apart at the factory seams.
