Usb Connections/serial -
stevefastv6
turboriv
What Aftermarket Dfi Have Usb To Computer Conn.? As Most Computer Man. Have Gone To Usb Ports Versas Serial Ports?i Have Turbolink And A Directscan I'd Like To W/ My Compaq Usb Port ! Thanks Sfastv6
I bought the cheapest USB -> serial cable I could find at Dalco, IIRC it was $15.00. Works like a charm with everything so far including T-Link.
I don't know much about other systems, but I do know that the FAST system does come with a serial port comm cable. Now FAST does have a USB to Serial port converter cable, that works. I have also heard that some others work, that you can buy at places like Radio Shack and such forth, but in most cases there seems to be a problem with other brands. Most problems that people run into using USB to Serial port converters is the fact that Windows likes to assign it to a Com Port that the after market systems does not recognize, so you will have to go in and change the com port settings within your Windows Device Manager. Hope this helps you some.
