Sep 20, 2009 #1 T TD2593 Grumpy Joined Jan 19, 2002 Messages 80 Whats the best USB to Serial adapter? My older laptop is toast and will be attempting to use a newer ACER usb only for my fAST tuning\logging duties.
Sep 20, 2009 #2 P pdzz fixing something Joined Sep 29, 2002 Messages 1,904 I found one on e-bay for 22.00, works great. I can't remember the make though. Phil.
Sep 20, 2009 #3 S S2V6RACER Banned Joined May 25, 2001 Messages 4,766 K-Span. It is compatible with Vista 64. I think the one FAST sells is the same.
Sep 20, 2009 #4 C Craig Smith That was easy! Joined May 25, 2001 Messages 1,147 Hi Russell, Specifically, the one you want is a Keyspan USA-19HS. Search on Google, Amazon, etc. for this part number and you will find it in the $25 range. Definitely the best-working and most reliable USB to serial adapter out there.
Sep 20, 2009 #5 T TD2593 Grumpy Joined Jan 19, 2002 Messages 80 Thanks fellas, Ill be getting a KeySpan it appears :biggrin: Now its time to bottom the wastegates out
