First, varify the block casting number ends with 109 on the drivers side.
Second, varify the turbo drain tube hole 1/2NPT is drilled into the pass side upper section of the block....If the block does not have the drain tube, its just a NA engine with the same timing cover, heads, flywheel,block and rods as the turbo regals... The crank wont be the same as the turbo regal.
Same block, just needs the hole drilled for the oil return from the turbo
Third, varify the cylinder walls still have cross hatches and the pistons are standard bore. Digital micrometer or look at the pistons, see if they stamped with the oversized piston number ...  .010 .020 .030 ect
Pull the pan, pull a rod cap off and varify the crank is a turbo crank with the rolled fillets on the rods and mains of the crank.
Na cranks dont have the rolled fillet on the rod journal, but still a good crank to use if you dont detonate it.
Make sure the head casting numbers end in 8445
Make sure the block isnt cracked in the cylinder walls, and make sure you take a flashlight to inspect the block, take a good look below where the main caps bolt to the block. This area is common to crack on a high horse power motor with weak main caps, the block will crack and it will have to be braised to strengthen it.
HTH
PS, just tore a friends motor apart tonight, cyl #6 was low on compression.
Turns out the piston was burnt and wore a .020 groove in the side of the cylinder wall... Car was running decent before we tore it apart.
Just goes to show you never know what your going to find, gotta make sure its torn apart completely to inspect every little bit of the block ect.
BW
