quickstrike
- Jun 4, 2002
Using N20 feature as trigger(FAST)
I use an electric motor in the fender well as a vucuum pump for crankcase pressure. I wire in a standard 30amp relay to activate it. Currently it gets activated when the key is turned on, but this is driving me crazy listening to if I just need power on the car for a few moments.
I would like to use the (pink wire I think) of the harness that normally would throw a ground for a nitrous solenoid. Only problem is after looking at the nitrous setup, I am afraid the ECU will attempt to command a new target A/F ratio when activated.
Target A/F when idling for me would be around 14-1 and I dont want it trying to change that value.
does this work, or is there a way around this?
Randy
Randy
