DOHC Vobra
- Mar 11, 2002
I was wondering if anyone out there has an idea if the WB sensor inputs can be used as an input to log a sensor that I'm using (specifially, a fuel pressure sensor that outputs from 1-5v). I don't have a WB 02 installed, so I should have those inputs open, but which FAST input would I connect the input to? I do see that the WB voltage can be logged in the dashboard... but does that work without installing the WB disk???
Thanks for any help!
Justin
'97 Cobra Coupe/FAST
Justin
