Working on the Stage 1 conversion and have run into a strange issue. I've replaced the braking systen, except for the power booster. Bled out the brakes and got out the air in the lines.
Have a hard pedel without the engine running, but if I start the car, goes to the floor with limited braking power. The original engine was a hot air 231. The car did this with both the 454 and with the Stage 1 455. Since everything has been tried I'm suspecting that the booster is incorrect and/or defective due to the stronger vac. signal of a larger engine.
Any ideas floating around? I am getting discouraged on this but will keep trying til its fixed.
